HP Spectre laptop running Windows 11.
I was going to do a scan of my wife's laptop. While setting up the scan I had a dialog box saying that I had software that was blocking the scan from going further. The dialog box said it was McAfee software which is not being used on that particular computer. I went into my Ccleaner and cleaned out the McAfee app and had to reboot as per the instructions. When I rebooted the computer again I had a blue screen and there was no pin box, just a message:
" Something happened and your pin isn't available click to set up your pin again"
AND:
" Couldn't turn on the camera".
I went on the Internet and there were solutions to this problem but in doing the solutions the files were not exactly like the instructions. Finally, I considered reinstalling Windows but received a message stating that to reinstall, without losing files, one must do it once your current Window app is running. I don't want to lose the files if possible. Please advise.
I tried to install a SanDisk that I created with Win 11 but it created more problems. See below. This screen opens and then after a minute
or so closes. I have not tried the F keys. Please Help.
RECOVERY
"Your device PC/DEVICE needs to be repaired. The header checksum for this file doesn't match the completed checksum"
File: \Windows\system32\winload.efi
Error code: 0x0000221
You need to use the recovery tools.
"If you don't have any installation media like a disk or USB device contact your PC 's administrator or PC device manufacturer".
Press enter to try again.
Press F1 to enter the recovery environment
Press F8 for startup settings
Press ESC for UEFI Firmware settings
Press F9 to use a different operating system
I guess I’ll have to take it in for repair unless you (or another forum member have a solution).
Thanks .
AND:
RECOVERY
Thanks .
