Laptop restrating problem
alex.stoychev
43
Hello...i have a Acer Aspire E1 571G from long time ago, but never had this problem before. When i play game or watching something for about 1-2 hours its suddenly shuts down and turns on again. I dont think that is a heat problem because I have a fan pad to cool it, its not even warm and i never overheat it.
Any help?
if temps below 75 under load for cpu and gpu then all and you could try update bios .. disable antivirus and firewall m and all malware programs then run exe. use power cable + battery pluggd in when doin g it
So.. after 30 min. under load my CPU is 55 degrees and my GPU is 55 degrees
Is that good?
Thank you for your advice...i will try it!
