Laptop sound not working. Tried many things already.
computer_newbie_30
6
Sony Vaio S, VPCSB28FJ
Windows 7 64-bit Home Premium
Audio: Realtek, Dolby
This problem occurred after I unattached the top section of the laptop.
Sound does not work even with volume maxed out.
I have tried connecting a working headphone to the unit and there is no sound to be heard on the headphone.
Volume icon has no red X on it and the volume bar (green bar) does jump when I click on the rocker in software.
The only time the sound works is when I connect a HDMI cable from the laptop to the TV.
I've already made sure the software/driver has been installed for this unit.
Yes I did.
Is sound chip or whatever it's called that controls the audio on the laptop integrated with the motherboard? I tried using the top section (with all the speakers and audio port boards) with a similar unit and it works fine. So it has to be something with the bottom portion.
Ken, you are right! I just came to the exact conclusion today but decided to purchase a new motherboard... and man is it expensive - $210 since it is for a newer model laptop.
I should buy a soundcard instead I guess.
Yeah, the laptop motherboards are not inexpensive. If you are not confident you can replace it yourself you will pay about the price of a new one between the cost of the motherboard and paying someone to install it. The less expensive option is the sound card.
