LASER LABEL PRINTER RECOMMENDATIONS
Good morning,
I am unsure if you are able to assist me, but I thought I'd give it a go!
I am looking for a colour laser printer that can print off labels roughly 16mm x 90mm. Ideally these would like to be weatherproof (if that's even possible). I would also like the ability to change what is printed (ie; text on label), preferably not through a third party application. I am open to printers that support rolls or sheets of vinyl. ANY help or advice would be greatly appreciated, as my printer knowledge is very limited. Thanks in advance!
Good morning,
Avery makes weatherproof labels -- https://www.avery.com/industrial/blank-labels-and-signs/material/weatherproof-white-film-labels
You should be able to use any laser printer. HP is the safe recommendation.
