Question Latency issues causing audio clipping
Feb 12, 2020
I have been searching what's going on a lot and I can not figure it out.
My stats from latencyMon
_
CONCLUSION
_
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. Also one or more ISR routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:09:30 (h🇲🇲ss) on all processors.
_
SYSTEM INFORMATION
_
Computer name: DESKTOP-K9MQD2B
OS version: Windows 10 , 10.0, version 1903, build: 18362 (x64)
Hardware: ASUSTeK COMPUTER INC., H170 PRO GAMING
CPU: GenuineIntel Intel(R) Core(TM) i5-7600K CPU @ 3.80GHz
Logical processors: 4
Processor groups: 1
RAM: 8132 MB total
_
CPU SPEED
_
Reported CPU speed: 3792 MHz
Note: reported execution times may be calculated based on a fixed reported CPU speed. Disable variable speed settings like Intel Speed Step and AMD Cool N Quiet in the BIOS setup for more accurate results.
WARNING: the CPU speed that was measured is only a fraction of the CPU speed reported. Your CPUs may be throttled back due to variable speed settings and thermal issues. It is suggested that you run a utility which reports your actual CPU frequency and temperature.
_
MEASURED INTERRUPT TO USER PROCESS LATENCIES
_
The interrupt to process latency reflects the measured interval that a usermode process needed to respond to a hardware request from the moment the interrupt service routine started execution. This includes the scheduling and execution of a DPC routine, the signaling of an event and the waking up of a usermode thread from an idle wait state in response to that event.
Highest measured interrupt to process latency (µs): 5413,30
Average measured interrupt to process latency (µs): 3,581183
Highest measured interrupt to DPC latency (µs): 3280,50
Average measured interrupt to DPC latency (µs): 1,596356
_
REPORTED ISRs
_
Interrupt service routines are routines installed by the OS and device drivers that execute in response to a hardware interrupt signal.
Highest ISR routine execution time (µs): 3395,858122
Driver with highest ISR routine execution time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Highest reported total ISR routine time (%): 0,117243
Driver with highest ISR total time: HDAudBus.sys - High Definition Audio Bus Driver, Microsoft Corporation
Total time spent in ISRs (%) 0,19990
ISR count (execution time <250 µs): 157458
ISR count (execution time 250-500 µs): 0
ISR count (execution time 500-999 µs): 36
ISR count (execution time 1000-1999 µs): 0
ISR count (execution time 2000-3999 µs): 227
ISR count (execution time >=4000 µs): 0
_
REPORTED DPCs
_
DPC routines are part of the interrupt servicing dispatch mechanism and disable the possibility for a process to utilize the CPU while it is interrupted until the DPC has finished execution.
Highest DPC routine execution time (µs): 5346,849156
Driver with highest DPC routine execution time: rspLLL64.sys - Resplendence Latency Monitoring and Auxiliary Kernel Library, Resplendence Software Projects Sp.
Highest reported total DPC routine time (%): 0,046342
Driver with highest DPC total execution time: nvlddmkm.sys - NVIDIA Windows Kernel Mode Driver, Version 432.00 , NVIDIA Corporation
Total time spent in DPCs (%) 0,140083
DPC count (execution time <250 µs): 660608
DPC count (execution time 250-500 µs): 0
DPC count (execution time 500-999 µs): 68
DPC count (execution time 1000-1999 µs): 7
DPC count (execution time 2000-3999 µs): 14
DPC count (execution time >=4000 µs): 0
_
REPORTED HARD PAGEFAULTS
_
Hard pagefaults are events that get triggered by making use of virtual memory that is not resident in RAM but backed by a memory mapped file on disk. The process of resolving the hard pagefault requires reading in the memory from disk while the process is interrupted and blocked from execution.
NOTE: some processes were hit by hard pagefaults. If these were programs producing audio, they are likely to interrupt the audio stream resulting in dropouts, clicks and pops. Check the Processes tab to see which programs were hit.
Process with highest pagefault count: skypeapp.exe
Total number of hard pagefaults 2818
Hard pagefault count of hardest hit process: 1041
Number of processes hit: 30
_
PER CPU DATA
_
CPU 0 Interrupt cycle time (s): 19,078357
CPU 0 ISR highest execution time (µs): 3395,858122
CPU 0 ISR total execution time (s): 4,534229
CPU 0 ISR count: 152380
CPU 0 DPC highest execution time (µs): 5346,849156
CPU 0 DPC total execution time (s): 2,846179
CPU 0 DPC count: 627387
_
CPU 1 Interrupt cycle time (s): 6,829794
CPU 1 ISR highest execution time (µs): 2219,756857
CPU 1 ISR total execution time (s): 0,024322
CPU 1 ISR count: 5229
CPU 1 DPC highest execution time (µs): 1516,78270
CPU 1 DPC total execution time (s): 0,254893
CPU 1 DPC count: 21083
_
CPU 2 Interrupt cycle time (s): 6,103702
CPU 2 ISR highest execution time (µs): 11,992616
CPU 2 ISR total execution time (s): 0,000296
CPU 2 ISR count: 112
CPU 2 DPC highest execution time (µs): 2549,784810
CPU 2 DPC total execution time (s): 0,060603
CPU 2 DPC count: 7264
_
CPU 3 Interrupt cycle time (s): 4,939538
CPU 3 ISR highest execution time (µs): 0,0
CPU 3 ISR total execution time (s): 0,0
CPU 3 ISR count: 0
CPU 3 DPC highest execution time (µs): 193,676160
CPU 3 DPC total execution time (s): 0,032995
CPU 3 DPC count: 4965
_
