How the hell do you tell what the max fps on an LCD will be? By max FPS i guess im relating to refresh rate (hz) from a CRT point of view.
Right now I have a 19" Samsung Synchmaster CRT with a native resolution of 1280x1024 hitting a max refresh rate of 85hz.
To my knowledge, this means on my current monitor the most FPS I actually attain and can display is 85fps/hz. Which is fine. When I drop my monitor to 75hz or lower. I can notice the flicket/FPS drop. It looks less smooth, and iritates my eyes quicker than 85hz.
Its 2008 and I think im finally ready to get me a widescreen LCD. I was trying to get me a 22" or a 24". Here's the problem I ran into 3 time.
2 LCD monitors I tried has native resolution of 16xx by 10xx....this is great....now before the next sentence, I do realise LCD dont actually have a refresh rate and update each pixel and the time it take to go from b-w-b is meased in MS. I.e. a 2-3MS monitor. I get this.
BUT, even with an LCD you still have the options/capabilities to change/set resfresh rate within nvidias drivers. So I suppose refresh rate in nvidia drivers for a LCD can be translated into "you gonna get this much FPS at most".
Here is where the problems start. 2 diff 21" LCD and 1 26" 720P TV have all been returned due to the fact the the "refresh rate" within nvidias drivers never exceed 60hz. So I never get more than 60 FPS.
This can cause a problem for someone who's been gaming @ 85FPS/HZ for 10+ years. LCDs give me headaches and I can't stand losing 25 FPS.
How the hell am i suppose to know what the "max fps/refresh rate" of an LCD monitor will be other than trial and error?
I tried to decipher the #'s @ sites , such as,
horizontal refresh rate = 25-92
verticle refresh rate = 35-75
the problem is, when i see those #'s i suspect that I can hit 75hz/fps @ the native resolution...WRONG. 2 lcds and 1 tv later, I have yet to see one that goes over 60hz/fps.
Can someone direct me to an LCD monitor that has a 85hz/FPS max or higher equivilency when compared to a CRT?
Thanks,
Thanks,
