Last night, a nightmare of every custom PC water cooler came true for me, my watercooling loop leaked. This was 100% my fault, for incorrectly screwing on the fitting after I flushed my loop. The fitting that came loose, just happened to be on the CPU block, which is right overtop of my GPU.
Water leaked on the backside of my graphics card (it has no backplate). I didn't realize this was happening (as I was watching a movie) until the screen started tiling, my computer froze and displayed the Windows Blue Screen for a second and shut off completely. I looked inside and saw a puddle of water sitting ontop of my GPU. I scrambled to unplug it, and as I was doing this, it sparked.
It's now the day after, I cleaned everything up, reassembled my loop (this time assuring I had the fittings on correctly) and started it up without the GPU in it.
Everything works fine, as I have given everything ample time to dry, including the graphics card. No burn marks or water damage is present on the GPU.
I am scared to plug it back in to see if it works, as it might spark and damage other things in my computer, but I'm unsure.
What should I do?
What should I do?
