[SOLVED] Led Button on Case
Dec 3, 2019
33
Hey there. I finished connecting all my cables for my build but I have two left which come from the case LED button or light button. They are connected to the button and case fans. I can't seem to figure out where those go. Thank you.
Unfortunately I can't find a manual anywhere online for that case. I'd assume the front panel LED button plugs somewhere with the rest of the front panel connectors on the bottom right section of the motherboard, but without being able to see what connectors the button and case fans are using, and without the case manual, I couldn't say for certain.
Thanks for your help. One moreover question. It’s fine that I connected two of my case fans thru molex, even if I left one system fan pin on the mobo.
Not sure, I can't find a manual or spec sheet anywhere for that case or its fans. I'm assuming if it's built for a molex connection (straight to the PSU?), it's probably not a PWM, and will run at full speed regardless of where it's connected.
