Question Led fan question
arkanine
14
I have a Thermaltake TH240 ARGB Motherboard Sync Edition, how do i change the fan color?i lost the remote and i am not sure what software from TT to download.
Gigabyte Z690 Aorus Elite AX DDR4
CPU
Intel Core i9 12900K 28 °C
Alder Lake 10nm Technology
RAM
96.0GB Dual-Channel DDR4 @ 1333MHz (19-19-19-43)
Motherboard
Gigabyte Technology Co., Ltd. Z690 AORUS ELITE AX DDR4 (U3E1) 33 °C
Graphics
Odyssey G8 (3840x2160@60Hz)
XB271HU (2560x1440@59Hz)
Intel UHD Graphics 770 (Gigabyte)
2547MB NVIDIA GeForce RTX 4090 (Gigabyte) 45 °C
SLI Disabled
Storage
931GB Samsung SSD 970 EVO Plus 1TB (Unknown (SSD))
14GB SMI USB DISK USB Device (USB )
Audio
Sound BlasterX AE-5 Plus
It did not recognize the fans, thats my fault i should have been more specific, this is what I am changing fan color on
Thermaltake TH240 ARGB Motherboard Sync Edition Intel LGA1700 Ready/AMD All-in-One Liquid Cooling System 240mm High Efficiency Radiator CPU Cooler CL-W286-PL12SW-C, Black
The gigabyte control center does not recognize the fans on the radiator.
After checking the fan control pins are plugged into the board , so im not sure what to do from here.
SOLVED- I tore the case apart looking for a unplugged pin, i found a hardwired remote that went to the cooling fans in the radiator i did not know about. Working perfectly now, thanks for the help[
