[SOLVED] Led won't turn off
Have you by any chance had your pc in a different location so that only now you can see the led's on the mobo.
This might seem a silly question but it is not.
Modern mobo's have pulsing lights working when the pc is turned off indicating they are using power from the main , this means that even with the pc off you can use usb sockets to charge phones and tablets.
You most likely have 'fast-startup' enabled. Check your motherboard's BIOS settings to see if the option is available and disable it, fast startup usually keeps your computer in standby mode even if you 'shutdown'.
Also check if fast startup is enabled in windows, follow this video:
View: https://www.youtube.com/watch?v=OBGxt8zhbRk
Tried it, didn't help still lights up
No I didn't same place from when I got it 🙂
I'll also mention that even If I unplug It, the PC lights still stays on
any other suggestion ?
Any labels, markings, or codes on the Red LED's to identify them?
Which Asus motherboard?
For example (taking a guess) I found the following User Manual link:
https://dlcdnets.asus.com/pub/ASUS/..._TUF_GAMING_X570-PLUS_WI-FI_UM_WEB_060319.pdf
Reference physically numbered Page 1-8
Red LED = CPU
And there are also red leds on the fans - correct?
Double check all connections per the manual.
Do verify that the manual I found is correct. If not correct, then search accordingly.
