M mineforce Prominent Oct 13, 2019 40 4 535 Oct 16, 2019 #1 Well, the title describes it. Is there a possibility I might be limited performance-wise like, for example, my Hz rate gets capped or something with VGA to HDMI adapter?
Solution SkyNetRising Oct 16, 2019 Depends on particular adapter. Most likely will be limited to 60Hz.
SkyNetRising Titan Jan 4, 2016 29,857 3,853 111,640 Oct 16, 2019 Solution #2 Depends on particular adapter. Most likely will be limited to 60Hz. Upvote 0 Downvote Solution
M mineforce Prominent Oct 13, 2019 40 4 535 Oct 16, 2019 #3 SkyNetRising said: Depends on particular adapter. Most likely will be limited to 60Hz. Click to expand... ok, no thats alright. It's not for my main monitor, it's for my secondary, which is 60hz so thats ok. Thank you Upvote 0 Downvote
