LG 25UM58-P monitor
pumaaaa
38
Hi! Is it worth to buy LG 25UM58-P monitor? It's 2560x1080 and is it better to buy that instead of 2560x1440 monitor?
2560x1080 is far easier on the GPU mate (what do you own) & the ultra wide resolution works great in driving & fps games that support it.
The issue is that a 25inch ultrawide has only the same vertical size as a 21 inch standard wide-screen - it's a lot smaller than you think.
You have to go with a 27inch to get comparable size to a 23.5 inch screen.
