LG 34UC98 34-inch Curved FreeSync Monitor Review
Nice article! There is a big problem though. LG is usually and unfortunately selling FALSE and FAKE advertising. They put unrealistic pictures of their products on the Internet, on the product's web page and even on the product's box itself. I see that, despite reviewing this screen you haven't provided a single picture of this product taken in real life (unlike those LG promotes the product with...cough, fooling its customers into believing the image goes from edge to edge only for them to find out there are thick black edges all around the screen, cough) - with the screen turned on.
Given how the screen looks like, I'm sure they keep promoting this "borderless" bullshit. Next time you review LG monitors, PLEASE take pictures of the screen turned on.
They literally mentioned their bezels were 1.2mm thick. Guess what, they are actually...wait for it... about 950% bigger - 11mm wide in reality.
Have a look for yourself at the results
Price tag seems excessive for such a small FreeSync range.
What happens if you exceed 75 fps (i.e. you have a high-end video card, or you're playing a graphically less demanding game)? Can't screen tearing also occur when your fps exceed the monitor's refresh rate?
I've had my gaming PC hooked up to an HDTV for the past several years, considering going back to an actual monitor.
Currently, I use a program called DXtory to limit my fps to 60, I've found that to be superior to v-sync, AMD's FRTC, and/or just letting the framerate run wild. I wonder if that would also work with a FreeSync monitor.
Anyway, great review!
I have a Dell U3415W, also 1440P, also has speakers and also Widescreen in 34 inches, rated by Toms as one of the best monitors for 2015..................Costs $650 or so.
I subscribe.
I happen to be the owner of a Dell UltraSharp U2515H and the image quality is exquisite. It's 1440p too, although only 25". My next monitors will definitely be Dell.
55Hz to 75Hz Freesync range?
WTF?
So you get the smooth game advantage ONLY if your frame rate is between 55FPS and 75FPS.
That SUCKS.
It means when you go above or below this value you either have VSYNC ON or VSYNC OFF. So you might get screen tearing every type you drop below 55FPS, but hitting 75FPS might force VSYNC ON so suddenly you have some added lag (a bit more sluggish).
*Far better to just NOT have the feature likely.
If they'd done 30Hz to 75Hz Freesync range then the low-end would have at least been fine as you'd be in asynchronous mode any time you are below 75FPS. In fact, you could just set a CAP near 70FPS and stay in asynchronous mode all the time, but nooooo.
Basically they must have SAVED A BIT OF MONEY by not supporting the ideal 2.5X minimum ratio for asynchronous range (75/30) so they could put the FREESYNC stamp on the monitor.
GSYNC might be more expensive but NONE of their monitors have this problem at least.
To Darth_Adversor->
Setting a cap of 60FPS would mean the GPU outputs a max of 60FPS and that is VSYNC OFF so you will get screen tearing though it may not be obvious for some games (it varies).
If it is a Freesync monitor and 60FPS is within the asynchronous range then the game should be smooth because the GPU dictates when the monitor updates so you don't get screen tear or added latency.
If it is a Freesync monitor and the range is less than 2.5X (75/30) you have VSYNC ON or VSYNC OFF (but not Freesync) if you drop below the minimum. If the range was 40Hz to 75Hz then any time you are below 40FPS you might get screen tear (or stutter if VSYNC is forced back ON).
If it's a normal 60Hz monitor then you simply limit the frame rate to one that matches the monitor. Since VSYNC is OFF you don't get the added latency of buffering to synchronize with the next refresh cycle (every 1/60th second), however you also aren't synchronizing when the frame updates either so you will get screen tearing.
If you have the latest AMD drivers, just turn the Auto Scaling on.
This will fix those black bars that you see thanks to your ignorance.
Just want to mention that i have the LG 29um67 Ultra wide HD freesync screen and man can i tell you guys it opened a whole new immersive world of gaming for me coming from a 16:9 24" screen. Feels like a cinema experience. Also i found it to be very practical for work.
I'll never go back to 16:9 aspect ratios :)
If fractions like 21:9 are allowed, then UHD must be marked as 32:16. For videophiles, who are in honeymoon with this ratio, why the void below and above the monitor is necessary? Isn't it more reasonable to flash mount tall display to the desk surface and cover larger (taller) field of view?
I love the idea of a curved monitor. However, we need applications that render properly for it. And we dont currently have applications that render properly for it.
If you actually took the time to read what I said, you wouldn't have sounded so ignorant yourself. How on Earth will your SuperDuper scaling fix the fact that a screen edge is PHYSICALLY there? Will it make them transparent so that LG's products end up being just how this company advertises them? The image reaches the edges and that's it, the output image NEVER gets OVER the physical edges unless those are transparent, but LG's shitty edges are as black as black can get. Again, the image will never be ABOVE the physical edges in order for you to see it (that's why they want to remove edges in the first place, DOH).
You haven't got the tiniest clue what you're talking about.
To people that believe that curved monitors are bad you have to look at how difficult it is to work on any monitor that is more than 24" big when it comes to the sides or the corners Simply put the monitors center is directly looking at you. The top corners are much further away from your eyes than the center and are facing many degrees away from you. Also the perceived colour space gets greatly distorted as the angle of the pixels change as your eye travels to the top left or right corner of the screen.
Curved monitors eliminate this to the most extent and it is actually a necessity with these larger than 30" monitors. Without the curve it becomes very uncomfortable to work on the edges of these monitors. With the curve it is still OK, the perceived colours are much more uniform and the distance to your eyes becomes a less varied.
I'd urge anyone considering this to compare the Acer XR341ck, which, near as I can tell, is the same thing with different plastic bits and tuned for a better freesync range. Same price, too.
What? No. It's literally a bezel. As in, it does not light up.
I haven't seen any false advertising from LG, though. On their own site, the picture show a turned-on screen with the true bezels visible. I like the current design since it makes it a uniform face and just looks nice. Not sure what he wants them to change.
What are you talking about?
1) 21:9 is the accepted way to describe this ratio (I believe it's for ease of comparison to 16:9)
2) in terms of mathematics, 7/3 is the same as 21/9
I couldn't even decipher your 32:16 comment.
Almost all manufactures sport "no bezel design" monitors which of course have a bezel but it is smooth and you can't see it when it's turned off. I was a little annoyed a few years ago when I first started seeing them, run 3 monitors and want no bezel, but it is a good looking design. LG clearly states bezel width in their specs and show it in images. Not false advertising, just somewhat misleading if you don't look at all the specs.
On this monitor, for me, I would probably only use one of them so it would be a non-issue. I have more concern with the VESA mount on these. I might get the Dell anyway.
LG lists this monitor as having a 11mm bezel, which sounds about right. I agree the pictures are usually deceiving but all you do is RETURN YOUR PRODUCT if you feel it's not what you thought it was.
LG has clearly done false advertising in the past however. If you watch the linked video that is very OBVIOUS.
Basically there was a thin, 1.2mm edge around the screen they called the bezel, however the actual viewable screen didn't reach this thin "bezel" so when you saw actual video you could the black area all around the viewable area.
Again, they specifically stated a "1.2mm bezel" and showed images with no video to mislead consumers, in an obvious attempt to get people who wanted triple-monitor setups with minimum gap to pay a PREMIUM price over similar items.
I'm not commenting about the product in this article but the one for another LG product that again was linked by someone else above.
@OMEGACLAWE This monitor is much better for productivity; it's a prosumer product and why it's higher price while something more dedicated to just gaming (not productivity) may be cheaper (but far inferior for productivity).
Monitors are indeed an investment, but it's a hard year to buy a monitor when you have USB Type-C, Displayport 1.3/1.4, Thunderbolt 3, DCI Color space, and OLED/LCD to consider.
I have this monitor for work and it's fantastic, but I know for gaming-centric needs, I'm waiting for an OLED 1440p to replace thinking about the ASUS 34" 1440p Ultra-wide w/ G-Sync.
I feel like most monitor companies are waiting for this Fall to reveal OLED 1440p monitors dedicated to gaming alongside a Big Pascal GPU reveal by Nvidia
