LG monitor corners turning red.
nkchokshi
Hi Guys i am having strange issue. I have LG's 27UD68P is a 4K led monitor.
Issue is, after using like 2-3 hours the corners of monitor turned red. After i turn them off like 30-40 mins, it goes away.
Now the technician didnt fine any issues, I still have a warranty but LG says there is no issue with monitor. Its like i am banging head to wall every day now. If you guys have any idea or solution. it will be big help. Thank you.
Hi Nitin thats the issue in india's service providers. They make you tired so much that you just leave those things.
Anyway i am going to mail their higher authority and consumer forums. Hoping to get proper answers.
But personally i dont know if that is overheating issue, panel issue or just led Backlight bleeding..
have you found any solution to this problem.?? i got the same monitor and i sent back to the customer support and now i got the same problem again. mine is only at the top left hand corner. its like a slightly burned color. not visible on white background but on blacks u can clearly see a red
