lg monitor LCD LED panel cracked
RaidenMGR
22
Hello.
Anyone knows where can i purchase a panel for my monitor?i had an accident the other night and my monitor has some cracks and cant display correctly anymore...i can find plenty of lcd panels at ebay but they are only for laptops..whats the case about monitors?
you can bring it directly to a LG dealer but expect to pay a lot, these panels you could be forking out quite a bit and that certainly isn't worth fixing it but more worthwhile buying a new monitor instead.
well that was what i was thinkink also, im still in warranty btw but no way they will fix it under warranty like this.I can pay maximum 50€ if i can find one, if its more than that then yea its better buying another monitor,so theres no way of finding a panel other than sending it to LG right?
Well, your best choice is to go to a LG dealer, but I wouldn't bother replacing it yourself as finding the right things can be unbearable.
