hello guys..for some time I have a problem with my monitor!!if I close my monitor and try to start it after an hour or if the power goes down my monitor wont open..it will stuck on a restart loop(I cant press anything on the monitor settings) and it will not properly open unless I heat up the chipset board.today I changed all the capacitors but It didn't fix the problem(I saw it at another forum as a fix).what do you thing is the problem?? my monitor is LG W2486L.thanks in advance!!
