[SOLVED] LG Monitor showing D-Sub error after 5/10 seconds. But my monitor still working.!!
Jan 4, 2022
My LG Monitor is working. But after 5-10 seconds its showing D Sub pop up in the right top corner of the monitor.
I've checked every wire connections but no fault found. I have no graphics card. using monitor in direct motherboard
Does that happen if you boot into Safe Mode?
Are there any other video cables being used: i.e., dual monitor setup? If so, disconnect the second monitor as a test.
References:
https://forums.tomshardware.com/thr...-used-available-in-d-sub-signal-only.3719857/
https://www.dell.com/support/kbdoc/...e-mode-error-when-booting-to-my-dell-computer
Research the problem but include additional search criteria as applicable to your system, components, and video connections.
Try to narrow down the circumstances and/or capture some specific error.
References:
