Question Lian Li Lancool 215: Build incompatibility?
Jun 30, 2024
17
So, the Lancool 215 case I bought early this month finally arrived, along with the other components. They are the following:
Motherboard: Asus Prime Z790-A WIFI
CPU: Intel i9-14900K
GPU: Sapphire NITRO+ AMD Radeon RX 7900 XTX Vapor-X 24GB
Watercooler: DeepCool LT720 ARGB 360mm
However, the GPU is larger than I expected, and from the looks of it, it doesn't fit in the case, unless if I'm missing something. Or maybe it'd fit without the watercooler?
I'd like some guidance, please. Because I'd like to keep this setup if possible instead of having to buy a different, bigger case.
https://lian-li.com/product/lancool-215/?cn-reloaded=1
RadiatorFront: 1 x 280/360mm
Top: 1 x 240 / 280 mm
VGA Length370mm
https://www.deepcool.com/products/C...m-Liquid-CPU-Cooler-1700-AM5/2022/16286.shtml
Fan Dimensions120×120×25 mm(L×W×H)
Radiator Dimensions402×120×27 mm(L×W×H)
https://www.sapphiretech.com/en/consumer/nitro-radeon-rx-7900-xtx-vaporx-24g-gddr6#Specification
Dimension: 320(L)X 135.75(W)X 71.6 (H)mm
370 - (25 + 27) - 320 = -2
The info on part dimensions was readily available...
Yes.
So I was stupid after all. It's the first PC I'm building so still too inexperienced with this stuff...
I guess I can still have an air cooler alongside the GPU though, right? In that case I'd be willing to sacrifice the AIO.
I'm willing to go with one from Noctua since it's a brand with high reputation. I also already bought some fans from them to add to the case.
This is their compatibility list for my case: https://ncc.noctua.at/cases/model/LANCOOL-215-4155
NH-D15 G2 and NH-D15 are too large. But NH-D15S (their third best) is compatible. My question is: would it still fit even with this large GPU at the same time? Just want a confirmation before I buy it and end up without enough space again.
Yes. Compatibility is the focus behind the S model; it fits around more cases/motherboards/ram than the other 2.
That said, Thermalright has their Phantom Spirit, Peerless Assassin, and Silver Soul 135 at more affordable prices.
