DIY way is most interested for persons prone to break things and sometimes make them better than original
I believe no one here knows about power button. However those usually are made quite cheap and simple. You can dismantle case front and see how that button look. I believe it is a piece of plastic with some regular push button and LED soldered somewhere below it. Maybe LED is even not soldered but simply hang around nearby.
Yeah... I know it's difficult. I don't feel like painting the LED, but finding a pro solution.... hahaha . I know I can do it myself, once I find the right solution.
I don't know if you know this particular case. The POWER BUTTON lays on the control panel located at the top of the case. Taking the front panel out, is not enough to see the control panel and the power button. I have to disassemble the control panel to see both the power button and the PCB and check out where the POWER LED is mounted.
The control panel has all the control cables going to the mobo, and all these cables are tightly tied within the whole cable management, along with all fans and RGC cables. I have to dismantle everything to be able to remove the control panel just to check if the POWER LED is integrated with the POWER BOTTON, or if it's a separate smd component below the power button, as you suggested.
If this is true, my issue is solved, because all I have to do is to replace the POWER LED for a WS2812b ARGB LED and plug it into my ARGB mobo conectors, such as all my other ARGB componets.
The problem is that after I dismantle everything (it'll take several hours), I come across with a POWER LED inside the POWER BUTTON which cannot be replaced.
That's why I asked for help here, among a lot of experts. To avoid all this work unnecessarily. Knowing the answer for sure, I don't mind all the required work, I'll gladly do it.
But if nobody knows this answer, I'll have to seriously think if I'm willing to have this hard work just to have a 50% chance of sucsess. Maybe when I can take some vacations, I'll have spare time just to risk.
But the solution is there: Replace the POWER LED, if and only IF this is possible.
Thanks again for your kindness and take care,
