Hi guys planning on building a new pc with the 4080 but wanted to know what case to use for it.
I've narrowed it down to 2 cases :
Lian Li O11 Dynamic Evo
Lian Li Lancool III
My parts : https://uk.pcpartpicker.com/list/KGmg4s
My question is if i was to build in the Dynamic Evo do you think that is a good idea / I have enough space to put in a 4080 and not worry about anything? Seen a lot of things about that fact you should have enough space for the 4090 etc. Granted i will be using a 4080 and its prob smaller but just wanted to double check before i buy the parts
I will also buy "Lian Li Riser cable PCIe Gen 4 60CM White" so that its got a cleaner route like the pics below.
This is what im looking to do with the 4080 View: https://imgur.com/a/T33yDYw
Thanks
Lian Li Lancool III
Thanks
