Lian Li PC-Q10 Build Compatibility
marcosmaia
Commendable
Dec 13, 2016
Hello guys,
I'm planning to do a kinda SFF build here, and i'm leaning towards getting a Lian Li PC-Q10, so i wouldn't have to buy new components (my mobo is already an ITX).
The things is, today i have an EVGA GTX 1070 (266,7 mm length) and an EVGA Supernova GS 550W (150,0 mm length). Lian Li's site shows that i have clearance for the graphics card (270,0 mm) and for the PSU (150,0 mm), but will i have for both?
Thanks.
I recently gave that for my sister in law as b'day gift, I figured because the connector's header will nudge the graphic card's PCB so I waited the EVGA G3, and it didn't. I can only suggest use lot of zip tie or unused cable (peal the plastic off). If you plan PSU upgrade, count SFF PSU instead.
Phew, thank god. I had recently bought this PSU (6 months old) and i was worried that i had to buy another PSU.... If i run into trouble with the cables, i'll try to get a hold of one of those flexible cables, like Silverstone's PP05-E.
