Lian Li's PC-011 Chassis Gets ROG Makeover
  • Thread starter Thread starter Guest
  • Start date Start date
I like this Lian Li case and I like the idea of dual chamber cases. Why do they all have to be E-ATX and 4 radiators gigantic? Could you imagine this same case in mATX or mITX size? I would like to see more snug fitting ATX dual chamber cases like the Riotoro CR1080.
Check out the Lian Li PC-Q37 - it is basically the mITX version of the PC-O11.
Nooo case manufacturer's need to go the opposite way in my opinion. These aren't "gigantic" radiators at all. I want to see more manufacturer's cater for people who want 140mm based radiators. Why does everything have to be 120mm? The maximum radiator size this case supports is 360mm which is a triple 120mm rad. It would be nice to see support for multiple 420mm rad support i.e. triple 140mm rads. I have an Enthoo Luxe with a single 420mm rad. Ideally I want a case that can support 2x420mm rads, but finding one that's aluminimum and tempered glass is almost impossible. The only other case that does this is the Phanteks Enthoo Luxe, but that's too big for my needs.. and too expensive. I'll buy this Lian-Li case anyway because it fits my needs, but it's just annoying having to buy 120mm fans again and letting my nine 140mm fans in my current case go to waste.
