Lian Li's fanless PC-Q04 chassis is making its way to U.S. store shelves for a friendly $59.
Lian Li's PC-Q04 Hits U.S. Shelves For $59 : Read more
You're right, thanks! It's fixed now.It looks like it would take a regular ATX PSU, not limited to SFX.
It will be a pain, but I would mount the board, then connect the cables, then shift the PSU into place.If I'm looking at this properly, it'll be very difficult to work on a motherboard in this case. The PSU is literally smack-dab in front of the motherboard, how are you supposed to connect stuff with the PSU in the way?
I wonder if you could get away with PSU and GPU that are able to shut off fans for low power, and a large passive cooler. That way, you'd have completely silent operation until you stressed it - like for gaming at which point you'd throw on your headset.
