Lights flash, fans turn on, no boot.
Smily1
11
Hello, I would like some help with this issue. I haven't finished building this PC yet but I can't get it to do anything so I'm not sure where to go here.
Hi, I'm building a new PC and I need some help here.
Specs
CPU: i7 4790
Motherboard: ASRock H97M Pro4
PSU: EVGA 550 GS
Problem
I can't get it to do anything, and I don't have a speaker so I'm not sure if it posts. When I press the power button or short the pins, all of the fans turn on, and the light on the case indicating the PC is on (it's a Fractal Design Define Mini) flashes for an instant and then turns off. The fans remain on until I press the power button again. I plugged the DVI output into a 2560x1440 monitor, and when I turn the computer on, the monitor wakes up and says "no dvi input", but it's at least recognizing something. This is the motherboard DVI output, not the graphics card. I have a GTX 950 that I plan to install but I haven't yet. Something that might be useful: when I took the heatsink off but left the fan connected, the fan ramped up in speed after a few seconds, because the CPU heated up (don't worry I turned it off before things got too hot)
What I've tried
1. Running with just one stick of memory in various slots
2. Disconnecting as much stuff from the motherboard as possible and trying to boot
3. Reseating the CPU and heatsink. I don't think I got paste on anything else (even though I definitely used way too much) and it doesn't look like any pins are bent, though I initially thought I bent all of them, but it's supposed to look like that.
4. Supplemental CPU power is definitely in. If I disconnect it while the fans are running, the whole thing shuts off.
5. The 24 pin motherboard connector took a lot of force to go in, though this seems fairly normal.
6. As stupid as it sounds, I cannot breadboard it because I cannot disconnect the SATA cables from the motherboard. They have little mechanisms to hold them in place that are supposed to be released when I press a button, but pressing it as far as possible isn't enough to release it.
Any help is appreciated. Thanks!
1| Here's a guide to building a new system
2| Here's a guide to troubleshooting when you can't get your system to POST
3| Can you please pass on your full systems specs inclusive of your ram and monitor?
4| You can try and wiggle the SATA data cables gently while the locking mechanism is depressed. You might need to go in with a thin plated flat head screw driver and see if you can depress the latch further.
* Off your motherboard specification's page
Graphics - Supports Intel® HD Graphics Built-in Visuals : Intel® Quick Sync Video with AVC, MVC (S3D) and MPEG-2 Full HW Encode1, Intel® InTru™ 3D, Intel® Clear Video HD Technology, Intel® Insider™, Intel® HD Graphics 4400/4600
- Pixel Shader 5.0...
- Pixel Shader 5.0, DirectX 11.1
- Max. shared memory 512MB*
- Three graphics output options: D-Sub, DVI-D and HDMI
- Supports Triple Monitor
- Supports HDMI with max. resolution up to 1920x1200 @ 60Hz
- Supports DVI-D with max. resolution up to 1920x1200 @ 60Hz
- Supports D-Sub with max. resolution up to 1920x1200 @ 60Hz
- Supports Auto Lip Sync, Deep Color (12bpc), xvYCC and HBR (High Bit Rate Audio) with HDMI Port (Compliant HDMI monitor is required)
- Supports HDCP with DVI-D and HDMI Ports
- Supports Full HD 1080p Blu-ray (BD) playback with DVI-D and HDMI Ports
*The size of maximum shared memory may vary from different operating systems.
**Intel® HD Graphics Built-in Visuals and the VGA outputs can be supported only with processors which are GPU integrated.
***Due to chipset limitation, the Blu-ray playback of Intel® HD Graphics is only supported under Windows® 8 / 8 64-bit / 7 / 7 64-bit.
****Intel® InTru™ 3D is only supported under Windows® 8 / 8 64-bit / 7 / 7 64-bit.
