Lights on fans spinning but no display
2chainzz
Hello everyone, I just recently got into building computers about a year ago. I built my first system last summer and everything worked fine. About a week ago I decided to get a new case and upgrade from a mid tower to a full tower. I also got a new PSU (EVGA G2 850W ) and a set of EVGA individualy sleeved cables. I did a case transplant and installed everything correctly (or so I think). In the middle of my case transplant my motherboard pins got bent a little. I used a pin and tried to bend them back as best as I could and they looked pretty perfect. I continued to install the rest of my components and booted the computer. My fans spin, my LED light strip lights up, and my MOBO light is green. Also my graphics card light is on. But I'm not getting a signal to my moniter. I also tested my monitor on another system and it worked fine. I'm thinking its a CPU/MOBO issue because my keyboard isn't lighting up either. I've tired resetting the BIOS and shorting the CMOS but that didn't work. The new power supply fan spin and seem to work fine. And is powering the MOBO. I really don't know and I'm open to any suggestions. Thanks to everyone.
Did you plug in all the cables, including the USB headers and perhaps your monitor? Try reinstalling your graphics card. Make sure your motherboard, cpu, and gpu power is all plugged in.
Is nothing showing on your screen at ALL?
Yes everything is plugged in properly... i tried reinstalling the GPU. And all my cables are plugged in and secure. Even my HDD is spinning! just no display... Im really leaning towards a CPU/MOBO issue. Im using a new I5 4690K so i really hope its not my processor.
