Hello,
So I bought a new PC. Nothing fancy, just for office uses. I'm using Samsung 19" display. Problem is, I'm seeing parts/areas, or more precisely, collumns (from top to bottom) of blurred fonts on the display, even as I type now. It's already set at its native resolution (1366x768 @60Hz). Everything is normal, it's just annoying to see. I hope it shows in the screenshot below (don't mind the language of the screenshot
Display: Samsung LED S19F350 19"
OS: Windows 7 64bit
Graphic: dedicated Radeon HD5450. I'm using AMD Ryzen, and for some reason I can't use the onboard GPU (there's no option to turn on onboard GPU in the BIOS). The store said that's just the way it is. Had it not Ryzen, then I can use the onboard GPU. I don't really understand, so I take his words on this.
Tried tweaking truetype fonts option numerous times, no improvements.
Thank you in advance.
OS: Windows 7 64bit
