L lgouveajr Dec 10, 2021 1 0 10 Dec 10, 2021 #1 Good morning, I have a LINKSKEY LDV-DM202AUSK 2-port Dual Monitor DVI and since I changed to port 1. I can't change back to port 2. Is there a way to reset the KVM?
Solution Ralston18 Dec 10, 2021 This KVM? https://www.newegg.com/linkskey-ldv-dm202ausk-dvi-usb/p/N82E16817402035 And the problem being that pressing/selecting Port 2 does nothing at all - not even the status light changes - correct? My first thought is that the selector switch has failed in some manner. Try plugging the Port 1 cables into Port 2 - just to rule out a potential cable problem.
Ralston18 Titan Moderator Oct 11, 2014 39,425 4,379 146,290 Dec 10, 2021 Solution #2 This KVM? https://www.newegg.com/linkskey-ldv-dm202ausk-dvi-usb/p/N82E16817402035 And the problem being that pressing/selecting Port 2 does nothing at all - not even the status light changes - correct? My first thought is that the selector switch has failed in some manner. Try plugging the Port 1 cables into Port 2 - just to rule out a potential cable problem. Upvote 0 Downvote Solution
