Hi yes, i think air cooling will be the best option for you. Watercooling needs to be done properly which means buying the highest quality parts and investing a lot of time in it. A good rad will just cost you around 130$. Core contact is a good choice, so is the true. here is a break down of my WC kit, it took me way 2 many hours to get the results i wanted.
XSPC rad = 130
3x Delta fan = 55$
Tygon 1/2 tubing = 30$
Distilled water = 3$
Swiftech Gtz = 70$
Danger den pump = 70$
Total = 358$ lol
i wasnt happy with my results before even after spending that much but after ocing my cpu it runs very very cool.
my temps with q9550 @ 3.85 ghz (1.27v, running intel burn test) are
idle 29-29-29-29C
load 42-41-41-41C
Ambient temp = 26C
Gl with your quest. Try to sell your kit on ebay if you can, i have seen them go between 65-90 dollars, or return it if you can
XSPC rad = 130
3x Delta fan = 55$
Swiftech Gtz = 70$
Total = 358$ lol
idle 29-29-29-29C
load 42-41-41-41C
Ambient temp = 26C
