Liquid Cooling Compatibility Questions
GMPoisoN
505
I'm only a tad confused on what I need to check for to make sure all of the components are compatible.
Res/Pump: XSPC X2O 750 Dual 5.25” Bay Reservoir Pump $59.99
Radiator: XSPC EX240 $52.99
Tubing: Feser One Clear UV $2.59/Ft. $25.25 est. price
Fittings: Free Center Compression Fitting $44.99
CPU Block: EK Supremacy Full Nickel $96.99
The block is G1/4", and that matches up with the port threading for the res/pump. The tubing is ID 3/8" OD 1/2", and compression fittings are 1/2"ID x 3/4"OD. Is the tubing and fittings not compatible because of the Diameters, or are they supposed to be different numbers so the fittings can fit over the tubing?
Sort of a noob question, thank you!
your tube and fitting not compatible, use the same size, tube with ID 3/8 OD 1/2 is the best flow result, so you have to match it with ID 3/8 OD 1/2 fittings, BTW you should pick another pump, your XSPC 750 pump only 1.60 PSI, try with stronger pump like D5 vario ( 4.75 Variable PSI ) or DDC 3.1 ( 4.39 PSI )
Thanks for the quick reply. I think I'm going to go with Monsoon Free Center Compression Fitting - 3/8"ID x 1/2"OD (http://www.frozencpu.com/products/16656/ex-tub-1332/Monsoon_Free_Center_Compression_Fitting_-_38ID_x_12OD_-_Modders_6_Pack_Blue_FCC-3812-6P-BL.html?tl=g30c409s1032) and would you say the pump in EK Dual Bay Reservoir w/ EK DCP 2.2 Pump Installed (http://www.frozencpu.com/products/17774/ex-res-465/EK_Dual_Bay_Reservoir_w_EK_DCP_22_Pump_Installed_-_Black_Acetal_EK-BAY_DCP_22_Combo_Unit_incl_pump.html?tl=g30c97s152) would be sufficeient, and would still fit with everything else? Thank you!
If you are set on an XSPC setup (they are very good) save yourself some time, headache and money and just buy their kit. You can get the RS240 kit for $144.99 or the RX240 kit for $174.
HERE:
http://www.frozencpu.com/products/16891/ex-wat-219/XSPC_Raystorm_750_RS240_Extreme_Universal_CPU_Water_Cooling_Kit_New_Rev_4_Pump_Included_w_Free_Dead-Water.html?tl=g30c321s1310
http://www.frozencpu.com/products/16893/ex-wat-221/XSPC_Raystorm_750_RX240_Extreme_Universal_CPU_Water_Cooling_Kit_New_Rev_4_Pump_Included_w_Free_Dead-Water.html?tl=g30c321s1310
They don't sell an EX240 kit, the RS is about as good for a lot less money, the RX is better than an EX if you want. Both kits have 7/16 x 5/8 tube, good stuff, your tube and fittings will not work together.
BUT, I think the Swiftech H220 is a better value at $139.99. It will do just as good of job if not better and easier to install, also you can add GPU blocks and such, and saves 2 bays.
http://www.frozencpu.com/products/18290/ex-wat-242/Swiftech_H220_Compact_Drive_II_Plug-and-Play_Liquid_Cooling_System.html?tl=g30c321s818
Well I'm not set on XSPC, I just opted not to go for their kit because I wanted a different CPU block, and tubing, and fans, and I'm using compression fittings and not the barbs it comes with, so It would be a waste for me. I just want to make sure this is all compatible. I thought the pump that the XSPC X2O 750 Dual 5.25” Bay Reservoir Pump came with was good, but I guess if I have to spend the $40 extra to get the EK one I will. remembering it's only a single CPU loop, I won't be adding a GPU block.
If you don't plan on adding a GPU or 2 then the H220 is perfect for you. Most AIO kits suck, only about a 1.2W pump, 1/4" tube and aluminum radiator. The H220 has a 6W pump, copper radiator and 3/8" tube. It is actually overkill for CPU only, if you want real cool add a radiator to it.
I just think you are wasting money and time for something you do not really need, but I am not trying to persuade you, just inform you. Buy what makes you happy, you are the bottom line in your system.
Well, although it may be overkill, isn't there really no point where you don't see a performance increase when it comes to water cooling? Say instead of the H220 I go with what I suggested. My water block is said to increase performance, lowering temperatures whilst under load during extreme gaming, so the money wouldn't be a, complete, waste of money, right? It's also kind of a hobby, and my first water cooling build, so I have the extra $$$ to blow on making it look nice. Is everything I listed compatible?
