Liquid Cooling Radiator making clicking noise
Could it be coming from the pump?
The bearings on the pump wear over time and the impeller shaft can start to wander and this will cause a noise and if you tap it....the shaft will move and ride in the right spot for a while and be quiet until it starts riding in the wrong spot again.
Follow-up:
It was an all in one kit from coolermaster so I'd rather not have to disassemble it.
Also I know it's the one fan because of where the sound is coming from. I could even double check my stopping that one fan with my finger and the noise would probably stop. Still can't see if anything is hitting it 🙁
