Hi,
I'm currently installing an EK-KIT X360.
Here is my current setup:
2 Front-mounted intake fans
1 Rear-mounted exhaust fan
Top-mounted Radiator /w 3, 120mm exhaust static fans attached (positioned BELOW the Radiator)
As shown here:
My question is: Do I have the fans and radiator positioned correctly in my case?
Also, here I have the Owner's Manual:
The diagram is what they recommend I do, however, since my Rad is serving as my exhaust (by entering my 3, 120mm fans and into the Radiator and out of my case), I won't have cold air entering the Rad, nor would I have the hot air going thru my 3 fans, correct? I'm quite confused when it comes to my current situation.
My question is: What should I do for my Tubing? Should I follow the manual in my case or change the INs and OUTs of the pump, waterblock, and radiator? The manual mentions that although the diagrams is "ideal," it is not mandatory. So I'm wondering if I could switch some of the INs and OUTs of the tubing, and if so, what would you recommend?
Thanks!
As shown here:
Thanks!
