Hi.
This isn't the classic push vs. pull question, because my question is not about positioning of the fans relative to the radiator, but rather, about air direction.
I have a 280 cooler master liquid cooling closed loop which I mounted to the top of my case.
Currently, the fans pull air from the case through the rad, and into the environment.
Is it correct, though? Wouldn't it be better if I rotated the fans so that they would pull air through the rad into the case?
I do have sufficient airflow in my case. I have two front fans pull in, and another one in the back pulling air right to the rad.
So, what should I do then?
