Yay, this again...
Air coolers put more weight on the CPU socket.
Meanwhile, LGA 1700 ILM warping:
The mounting system allows for the motherboard and part of the case(see motherboard standoffs) to support the weight of an air cooler standing sideways.
Nothing to really worry about, just don't travel with an air cooler mounted to the motherboard. They weren't designed for that.
not true , many AIO coolers are not more expensive when you calculate Watt TDP per dollar cooling.
A new cooler must be bought after an indeterminable amount of time has passed, due to one of the inevitable failures rendering an AIO unusable e-waste(mechanical/chemical/biological). An air cooler doesn't have this con, unless it's one of those dated push-pin models. They can be reused in other PCs and last virtually indefinitely. Instead, they get replaced:
-if a new case isn't compatible with it.
-the user gets tired of looking at it(if the case even allows for viewing the interior).
-the cooling isn't adequate for the cpu + use scenario.
-the user breaks it, for some reason...
One of those reasons isn't necessarily a mandatory one.
If the PC helps put food on the table, I hope folks who use AIOs have backup coolers on hand. [This means buying 2 coolers, instead of having the one air cooler.]
Time is money, and all that; it wouldn't be great if the PC was/went down at a bad time due to AIO failure.
it does matter , because water cooling will keep the entire system cooler and more silent as well. heat builds up with time faster in air coolers .and the Turbo Mode will be at max for longer time when it sees lower temps.
Temperatures: ✋
Watts: 🫵
Liquid coolers actually increase ambient(case & room) faster than air coolers, and ambient affects the min/max operating temperature of all devices.
Certain PC parts boosts higher and for longer, thus use more heat energy(in watts) when using them, meaning they are using and dumping more heat energy into the case, and or room, than air coolers.
Temperature is not a measurement of the heat energy being used, and IMO, there is too much focus on it and not enough on watts, out there in the community.
