Load Balancer Question!
moed85
Hi, I currently have the TP-Link TL-R480T+ load balancer with 3 ISPs connected to it through cables. As you may know it doesn't function as a wireless router which I really need..
My question is how to make this load balancer goes wireless? Do I have to buy something like the TP-Link TL-WA901ND and connect it to the load balancer though cable and then it would successfully wireless all 3 ISPs?
Sorry I'm kinda noob.
Thanks!
Not sure what you are now asking.
The purpose of the balancer is to connect end devices to the 3 ISP. A AP is just another method of connecting end devices. It will work the same as if you had plugged a pc into the ethernet cable...the balancer does not actually know that there is a wireless signal that was converted to etherent. Depending on how you configure the balancer it will allow access to all the ISP no matter if the signal came from a actual ethernet pc or from one connected via the AP
Now if you are asking that the WAN connection to the ISP themselves is wireless you need a very different device to do that.
Bill,
So there's no way to wirelessly connect to all 3 ISPs then?
