Logitech Dual Action Gamepad problem
saazeel
21
I've recently purchased a Logitech Dual Action gamepad. The wierd thing about it is that the D-pad works with some games, but doesn't with others. For eg. the D-pad can be used in NFS Underground and Pro Evolution Soccer 3, but no matter how I tinker with the configuration utility and setting options, the D-pad just doesn't work with Tony Hawk Pro Skater 3 and FIFA 2004. I therefore have to use the analog stick for these games, something I'm not particularly fond of. I haven't found a way yet to switch modes between analog and D-pad control on this gamepad (I don't know if that is possible on this gamepad).
Any suggestions?
Thanks 4 your help
If you can't program the functions directly you can assign the gamepad buttons (with every gamepad I have seen) to keyboard keys then you have the game use those keys for the functions. Now each time you press a button on the gamepad the utility sends the keyboard key code instead. It fools the game.
It's a workaround but you can even use that method on really old games that normally only expect a keyboard. Makes gamepads very flexible.
<b>56K, slow and steady does not win the race on internet!</b>
Hey,
You might want to check out www.wingmanteam.com, I was pretty frustrated when some games didn't allow me to play with the d-pad because it seemed as if the left analog joystick was the primary controlling device. But goto the website, and look around, they have a "beta" update to the 4.30 drivers (which you might want to grab from logitech if you havent yet), but it's a separate proggie that allows you to switch the left joystick with the d-pad, or switch the two analog joysticks, and some other stuff I didn't see any use for(for me).
Even better, here, have the website (I found it in my history!). I hope this helps you out. Enjoy!
http://www.wingmanteam.com/latest_software/beta_main.htm
Remember, when in doubt, even monkeys fall from trees sometimes.
