If the Logitech G700s is plugged to its USB cable (for recharging) and later the PC goes into sleep (whether on its own or by pressing the case button), the PC enters a semi-sleep state. It needs a hard reboot and a visit to the BIOS to have the PC operational again. This is a systematic failure. Luckily, other than the annoyance, it has no further effect on the PC.
The details:
My new G700s is working perfectly, wireless or wired, with the following proviso. If have it wired (typically for recharging) when the computer goes to sleep (either on its own or pushing the case button), this sequence follows:
1) the PC enters an abnormal state: the sleep light blinks, but the hard disks keep spinning.
2) the PC becomes irresponsive to anything, and only a hard reboot can restart it.
3) the reboot fails with a memory check following by an "overclocking error" (there is no overclocking).
4) the only way out of this is to enter the BIOS, exit with save and reboot.
5) after the usual "(Windows did not shutdown properly") message, the PC works OK again.
It is now apparent that the only cause of the behavoiur is the PC entering sleep while G700s is connected to the USB cable, because otherwise my PC performs flawlessly.
For the time being, I am recharging the G700s outside the PC using USB cable into mains adapter.
Anybody else with this issue? Is it an incompatibility with my motherboard? Any solution?
I have posted the above in Logitech's forum a month ago. There have been no answers.
Joe Claudio
(retired PC technician)
CPU: intel i7
mobo: Asus Rampage III Extreme, X58 chipset.
OS: Windows 7 64-bit
RAM: Crucial 12Mb
G700s: installed latest Gaming Software v. 8.53.186.
G700s cable: plugged directly to a mobo USB2 socket.
The details:
Joe Claudio
CPU: intel i7
RAM: Crucial 12Mb
