Logitech G910 Key pressed with extremely light pressure and sometimes sticks without being pushed down
highpr
11
I have an issue with my Logitech G910 Keyboard.
My "L" key gets pressed without me putting any force behind it at all, the slightest of touches makes the register and I get stuck with "L" being used multiple times. I also have an issue where I press the key and nothing happens to it at all. I also have the exact same problem with my "T" key very rarely. Anyone know if this is a common issue or something I can take to Logitech and contact them about it to get a replacement or something?
Any information will be grateful.
Thank you,
highpr
Have you tried taking the cap off and seen if its dirty underneath? they caps come off pretty easy - helps to take photo of keyboard so you know where they all go back on. There are videos online about cleaning it.
mute the sound, its bad:
[video="https://www.youtube.com/watch?v=uEtxL0EOw-E"][/video]
I found my r key used to repeat a lot but it doesn't do it as much or I have adjusted to the keyboard. I have a G910.
Thanks for the response Colif. I have removed the key caps around the L key and focused on that area it self. And after testing it before cleaning I notice the issue occurring. I then proceeded to clean it and I'm fairly sure its an issue with the switch it self because with slight wiggles of the switch it registers the key, I have done the same thing to other keys that do not present this issue and they do not get registered. So I probably might go to Logitech's support and explain everything there. Thank you again Colif.
