Logitech Gaming Software makes my left click double click
joshwilkinson99
69
i was messing about with my appdata folder yesterday, and since i started to use my computer today my logitech gaming software makes my mouse left click double click when i press the left mouse button once. When i go onto device manager and roll back the driver, this does not happen which means that it only happens when i am using the gaming software. does anyone know how to fix this problem because i can not play games without the software installed because of ingame keybinds, the mouse is a logitech g600. I have tried to re-install the program multiple times, i've tried to use older versions and it happens with every version.
Thanks
Edit: this only happens when I'm on automatic game detection, but does not happen when i'm using the On-Board Memory setting
i managed to fix the problem on my own somehow, by deleting the logitech folder from appdata then reinstalling it, becuase i thought this would happen on its own, but thanks for the reply and suggestions,
Thank you for posting this, over a year later and it solved my problem!
hi i have had 3 g600s in the past 5 or so years and they are great. 2 died on their own eventually but the last one i got second hand and has a (seems to be software) issue where it keeps wiping my default profile and when i remake it it gives me this double click error.
deleting app data and reinstalling has fixed the issue twice now. thank you for answer above and anyone else should try same GL :)
then save your profiles somewhere safe after just incase it happens again and update to latest version
