Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
On Fri, 17 Dec 2004 09:03:34 -0800, "JAD" <kapasitor@charter.net>
wrote:
>Freakin setup....so you can explode your prowess to the functions of
>batteries.....WRONG! indeed...there in for more than a month- 3% to
>10% a day would be ridiculous............ and its was an arbitrary
>remark...the gist is....there in- they work -and don't die in a
>week... of course if your constantly using a keystroke to zoom in and
>out of porn pictures your battery life will suffer......allota nothing
>bout nothing
No need to get all pissy.
I have no expertise in battery technology (witness my goof regarding
the big loss of charge during the first 24h), just been looking into
different battery techs with a view to building up a rechargable pack
for a bike light.
Look on the bright side: We both now know a little bit more than when
this thread started.
><<How is the remaining charge being measured?
>With a battery tester,,,no wait I put them on my tongue\\
I'd treat the charge indicator on a consumer-grade battery charger
with a degree of scepticism - NiMH's have a very flat discharge curve,
so deriving the state of charge from their voltage is going to be
pretty inaccurate. The charger *could* be pushing some charge into the
batteries, and looking at dV/dt, and guesstimating from there, but I
doubt it.
Doesn't really matter anyway, since small NiMH's are so cheap these
days, who cares if you only get 300 charges out of them due to a
little mistreatment, rather than 500?
>cousin of _tom?
>"nobody" <nobody@nowhere.com> wrote in message
>news:7k26s05kdcn4pdnopfofrp1v2oa9r9mbem@4ax.com...
>> On Fri, 17 Dec 2004 07:59:34 -0800, "JAD" <kapasitor@charter.net>
>> wrote:
>> >...well that would put these Ni's at a (negative) -8 volts by
>now......
>> Wrong.
>> Self-discharge refers to reduction in a battery's real capacity,
>> rather than (specifically) its voltage.
>> Say your NiMH AA battery has a capacity of 1400mAH and it's fully
>> charged and topped-off.
>> Leave it on the shelf for 24 hours, and its capacity is now:
>> 1400 - ((1400/100) * 3) = 1358mAH
>> (assuming a 3%/day self-discharge rate)
>> Leave it on the shelf another 24 hours, and its real capacity is:
>> 1358 - ((1358/100) * 3) = 1317mAH
>> ...etc etc.
>> >...KB NI's are in for over a month now....still over 60% of the
>charge left.
