Logitech z506 5.1 surround sound speakers.
josh791
63
I just bought these speakers and tested them out. I could not get the rear speakers to work in 5.1. I have looked up other solutions but nothing works. I have an MSI Krait Edition Motherboard. I have tried rewiring to different spots and nothing has worked so far. I know the speakers work in 7.1, but they do not work in 5.1. Any suggestions on how to fix this problem?
I have the z506. I used creative z series control panel to isolate each speaker and make sure it was correct. I had to do a little messing with the connections on the woofer to get everything right. I think that mobo has creative software with it that will allow you to test each speaker individually.
Make sure you have the three colored cords that run from the woofer to the mobo right and then the rest will work out nice when you use creative's software to work each speaker.
Latest posts
