Greetings,
I have a situation where all (4) PCI slots on my mobo are filled with the same double-width GPU and the last GPU is physically blocking access to the system panel jumpers.
Does anyone make a reputable 90-degree jumper block?
So far, I have found this, but am not sure if it's the correct item or a legit vendor.
http://starconnect.en.made-in-china.com/product/HBDndUkVbWhE/China-2-54mm-90-Degree-Break-Away-Pin-Header-Female-Double-Row.html
Any help would be greatly appreciated!
thank you
thank you
