Looking for a PSU for an old system E8400
cynicoren
297
Hello,
My old PSU has probably died. The system had an overkill 610 PSU.
I'm looking for a new one that will last, but will not be too expensive since it's for my son's PC.
The main specs are: E8400, GA-X48-DS4, Sapphire 7850 HD, running now about 3 internal HDD + 1 SSD.
Thank you
Seasonic G550 is good enough wattage and the best quality
With 3 HDD and an SSD 610 is not overkill. That said you don't need a $200 PSU to run the system.
This is 50 bucks, its Tier 3 and will do the job:
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438012&ignorebbr=1&cm_re=EVGA_PSU-_-17-438-012-_-Product
This one is better and also $50 but after rebate
http://www.newegg.com/Product/Product.aspx?Item=N82E16817438025&ignorebbr=1&cm_re=EVGA_PSU-_-17-438-025-_-Product
You're going to get much higher end suggestions here. Don't waste the money.
Thank you. It seems that my technician is holding only these brands - Thermalake, Corsair, CoolerMaster and Seasonic (g-550, g-650 and X-series 650).
Can you please recommend any from these brands ?
