[SOLVED] Looking for a smaller case, need advice.
Servs
45
I currently use a Phanteks P600S and im in love. But im moving everything to a smaller desk and i want the pc to stay on the new desk which it wont be able to do with the current case.
I also plan on doing an upgrade to my parts, which will affect the case i can use. These are my current parts:
CPU - Ryzen 9 3950X
Motherboard - Asus Crosshair VIII Hero Wifi
GPU - RTX 3080 FE
CPU Cooler - Corsair H150i Pro
SSD #1 - Samsung 970 EVO Plus
SSD #2 - Samsung 970 EVO Plus
PSU - EVGA G1+ 850watt
Case - Phanteks P600s
PCIE Device - Single Slot Capture Card
I want to swap the CPU cooler for an NZXT Kraken Z53/Z63, then add a NZXT Kraken X53/X63 with the NZXT G12 to the RTX 3080.
Are there any cases smaller than what i have that could accommodate this? Anything tall but slim?
Im willing to swap the PSU to SFX and the motherboard to M-ATX if it helps find a case,
The motherboard you have requires a full size ATX case, using SFX power supply doesn't help as other components (like GPU) still have the same ATX size.
