Question Looking for a specific Motherboard. Please Help!
aGuillermo
33
I am looking for a micro ATX motherboard that has a LGA 1151 socket and compatible with a i5 7400 (non-k) and is specifically 9.4x9.4 inches or smaller in dimension. This is because I am upgrading the motherboard of a prebuilt my friend has from HP (bought at best buy) and the case looks custom/proprietary as the motherboard needs to be the exact dimensions above or smaller or else the new motherboard won't fit. I checked some mATX mobo's on Amazon and some are larger in size than what i stated above, so that's why i'm stressing the size so much, as his current mobo fits perfectly snugged in his case.
His current motherboard is the ipm17-dd2, i've tried finding a new motherboard myself on amazon but haven't had much luck, so i thought i'd come here. Preferably, the new motherboard could be sub $100.
Thank you in advance to anyone that can help. Appreciate it so much.
