looking for advice on animation vfx cg specifications hardware
nishicant
Commendable
Aug 18, 2018
i want a pc for animation, vfx, cg modelling & rendering, video editing etc. i've finalized the following specifications-
processor: amd ryzen 2700x (8 cores)
motherboard: asus prime x470 pro
graphics card: zotac blower geforce gtx 1080 ti (8 gb)
ram: Corsair 32 gb ddr4 (16x2)
ssd: samsung 500 gb
hdd: wd 2 tb
monitor: 4k uhd
i've following questions-
1. any suggestions/alternatives regarding above specs?
2. what are required psu specs?
3. what are required ups specs?
4. what cabinet and liquid cooling is suitable?
Ram = get a DDR4-3200MHz dual channel kit. It'll benefit your platform.
PSU = a reliably built 650W unit that has high efficiency rating since rendering will entails your system runs for long hours. I'm also gauging that this system will be a bread earner, am I right? If so then your return on investments need to be factored and every bit of performance needs to be added/squeezed from it.
You need to list your proposed specs like so:
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
On another note, it'd be a good idea to list all the app's/software you're going to tax yourprofessional build.
Where are you located, how much are you willing to shell on the system and what is your preferred site of purchase?
CPU:
Motherboard:
Ram:
SSD/HDD:
GPU:
PSU:
Chassis:
OS:
