Looking for advice on either upgrading fully or just buying some parts
Matt_owen1
13
Hi, I currently have:
I've been told before that I need a new power supply and graphics card.
I've been looking at buying a NVIDIA GeForce GTX 970 4GB and a 600W power supply, but I'm wondering if it's worth buying a whole new build or can this graphics card work pretty well with my current build? I play games such as Dayz, League of legends and I want atleast 120 fps on League.
Wrapping up, is it worth me buying a i7-4790K Quad Core 4.00 GHz 8MB+ 600w power supply + NVIDIA GeForce GTX 970 4GB in a pre built or just swap out some parts in what I currently have, thanks for the replies in advance.
( If you could post a pre built better than this as my budget will be around £700 ish it would be appreciated. )
http://www.ebay.co.uk/itm/Intel-Core-I7-4790-1tb-8gb-1600Mhz-GTX-970-4gb-Galaxy-Computer-Gaming-PC-/151460585335?pt=UK_Computing_DesktopPCs&hash=item2343c11f77
Thanks! so It's fine for me to go out and buy a power supply, and a graphics card and it's all compatible and ready to just slot in? that's pretty much all I'm worried about.
Yes you need a new power supply and the GTX 970 is a brilliant card. You could also upgrade your motherboard and get a better cooler and overclock the fx6300. But only if you can find a good deal on a motherboard.
Sorry at work and we have blocks for ebay and such. Please post what it is and i'm happy to help.
MSI 990FXA-GD65, AMD 990FX, SAM3+, DDR3, PCIe 2.0 (x16), 2 Way SLi / 2 Way Cross
Or if that's not very good, could you suggest one for roughly £100-150, thanks!
That motherboard will be fine, its the the 990 chipset which is the best amd overclocker at the moment. Add something like this one http://www.coolermaster.com/cooling/cpu-air-cooler/hyper-212-evo/
and you'll be flying. Push that fx6300 up to 4.2ghz at least.
So wrapping up with your amazing help, if I buy:
£? power supply - 600w gold rated
£115 - motherboard MSI 990FXA-GD65, AMD 990FX, SAM3+, DDR3, PCIe 2.0 (x16), 2 Way SLi / 2 Way Cross
£240 graphics card - NVIDIA GeForce GTX 970 4GB
£25 cooler - Hyper 212 EVO
It should drastically increase my gaming performance, and It should last for a good while before I should need an upgrade
Yea that looks good you will even be able to get another GTX 970 in the future and sli. Make sure you get a good power supply. Choose a good brand Corsair, XFX, Seasonic etc with a Gold 80+.
You may also want to get a 700-800w one to cover you for any future upgrades.
Thanks so much for your help! New parts incoming :)
