Question Looking for earpieces with long battery and reliable multipoint
umby75fg
5
Hi!!!
So far I found my old Oneplus Z quite good for my needs. However, recently I noticed a strong deterioration of features due to a battery issue (I bought 3 from a store with the same issue!!. Moreover, the technical service looks worse like the earpieces). The model Z2 looks more reliable but the multipoint feature does not work like the "Z" model (that is, you are forced to switch through your phone in Bluetooth settings for earpieces selection and you need to press for a longer time the proper button on the earpieces, etc., if it works at first attempt.....). I am looking for similar earpieces, with durable battery (at least 10 hrs), enhanced multipoint and cable that connects the two earpieces and possibly cheaper...
Do you know what could be worthwhile to buy?
Thank you for your advice!!!
Where are you located, what is your budget and what is your preferred site for purchase?
I've personally have used AudioTechnica ATH-SQ1TW and they did last a good 6hrs for me.
Hi!!! Thank you for reply!!
I prefer the neckaband because they are more durable and more practicle to use. I need minimum 10hrs.
The budget is about up to 60 Euro and I am based in Rome (IT). Moreover, I don't prefer any store in particular, as long as itcis a reliable one...
