Question Looking for good rgb fans for case and cooler
ciprianburbulea
43
As the title I currently have a thermaltake p6 which is mostly glass but ill be putting 10 fans in it. I was looking at thermaltake pure 14 argb fans thought i might aswell go with thermaltake just like the case but thats not a necessety.
I don't really know much about good rgb fans. Ah ARGB fans I need because I have a 10 fan hub but I am not sure what fans to get that are good looking and good performance.
Also tehnically it will be 13 fans because I will be switching the ones on the AIO too but those i guess ill use splitters and connect to CPU FAN.
Help is appreciated thank you!
a good cooler will come with a combo cable that will run all fans to the CPU_FAN header.
usually they make it pretty easy to setup.
just make sure they have a high airflow(CFM or m³/h) rating, lower sound(dB/A) rating, and depending on where they may be placed a higher air pressure(mmH20) rating.
be quiet!'s Light Wings are very nice.
