looking for gpu cooler for club 3d radeon 7750 gpu
Asil786
40 pounds is the budget but can stretch if the difference is worth it maximum 50 pounds, my temps go over 85 degrees when gaming so need a good cooler as the gpu fan stops at a certian temp, in my previous thread
Thanks
Which version of the Club 3d card are you running?
If your card is overheating most likely it is the thermal paste on the card or bad case airflow causing high temps.
Buying an aftermarket cooler is also not really worth the cost for a lower end card.
However these should fit your card.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186053&cm_re=Accelero_L2_PLUS-_-35-186-053-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=6146846&SID=i6frmi44kr000kb500053
http://www.newegg.com/Product/Product.aspx?Item=N82E16835186052&cm_re=arctic_cooling-_-35-186-052-_-Product&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=6146846&SID=i6frnkkz5p000kb500053
If you don't live near newegg just find the same product near you.
-good luck
well, the card runs games on high settings until the stock fan just stops as it is faulty, more details in previous thread, the game runs smoothly (shadow of mordor) until temps get high so i thought better cooling would solve this, also the twin turbo 2 doesnt fit my card as i checked on their site and no compatibility, i was looking at the accelero s3 and i was going to attatch my own 120mm fan to it instead of their turbo modules.
http://www.arctic.ac/eu_en/accelero-s3.html
