Looking for Help/Advice.
fckayoo
8
Hey guys, im looking at making my first build sometime in the future(i guess you can say im still a newb, so im not sure if everything is compatible). So im just looking to get some help/advice to see what things i can change.
Preffered Websites : Newegg and Tigerdirect
Budget: $1000-1150(I live in new jersey, so i get charged tax from newegg)
Parts Not Needed: speakers,mouse,keyboard,monitor
Overclocking: No
Uses: Gaming,Internet,Just everyday use
(Im looking at an AMD build just because i want to keep my budget and the only intel CPU i would like would be an i7 920)
This is what i have right now:
CPU:AMD Phenom II X4 940 Deneb 3.0GHz Socket AM2+ 125W Quad-Core Black Edition Processor Model HDZ940XCGIBOX - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.182217
$290
(the bundle includes Vista 64bit)
Motherboard:GIGABYTE GA-MA790GP-UD4H AM2+/AM2 AMD 790GX HDMI ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128384
$130
RAM: 2 OCZ Fatal1ty Edition 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820227364
$90
Case:Thermaltake Armor+MX VH8000BWS Black Aluminum / Steel ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133062
$120
(i really want this case, so unless there's a big problem i would really like to keep the case)
Video Card:ASUS EAH4890/HTDI/1GD5 Radeon HD 4890 1GB GDDR5 PCI Express 2.0 x16 Video Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16814121308
$260
(this would be one of the items im not 100% sure if its compatible with everything, if not 4870??)
Harddrive:Western Digital Caviar Black WD6401AALS 640GB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5" Hard Drive - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
$75
(if needed i could probably cut down on my harddrive cause i dont need too much space)
Power Supply:SIGMA MONSTER SP850C 850W Continuous @ 40°C ATX12V 2.2V / EPS12V 2.91 SLI Ready CrossFire Ready Modular Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817226009
$120
DVD Drive:ASUS Black 18X DVD-ROM 48X CD-ROM SATA DVD-ROM Drive Model DVD-E818A3T BULK - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827135181
$20
(i dont really need a high-end DVD Drive)
Total:around $1105 (without taxes or shipping)
Once again i'm not going to be overclocking so do i really need a cpu cooler? i should be fine with the stock cooler right?
Im not a really big gamer, so i dont need an intense gaming computer.
Also sorry for any spelling mistakes i might have had :).
Thanks.
The build looks pretty good overall. The RAM could be improved, though. CAS 7 is pretty slow. You'll want to look for a quality CAS 5 kit.
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 1066 (PC2 8500) Dual Channel Kit Desktop Memory - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231166 $54.99
I would just go with the Corsair 550 VX or 650TX since you said you don't really play games (I doubt you're going to be adding another GPU for crossfire).
CORSAIR CMPSU-550VX 550W ATX12V V2.2 SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139004&Tpk=550vx $94.99 - $20 MIR
CORSAIR CMPSU-650TX 650W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Certified Active PFC Compatible with Core i7 Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139005&Tpk=650tx $109.99 - $20 MIR
The DVD drive you picked doesn't even burn DVDs. A quality drive is only a few bucks more.
LG 22X DVD±R DVD Burner Black SATA Model GH22NS30 - OEM
http://www.newegg.com/Product/Product.aspx?Item=N82E16827136152 $24.99
No, you don't need a CPU cooler if you're not overclocking.
